Hey guys ive searched the site and tried every suggestion but ive come up empty. I have a 94 integra SE with a b18b1
I have fuel spark timing and compression but a crank no start. Ive replaced my dizzy with a known good one from a friend, checked mechanical timing, got fuel coming out the new filter, new plugs smell like gas, plugs were gapped, each new wire sends sparks and a loud and bright crack that can be seen during daylight, didnt measure compression but the finger test and putting and empty spark plug wire and cranking it sends it to the ceiling suggests its fine, starter was tested, new alternator within a year along with battery, main relay clicks with each key turn, fuse 24 and pgm fuse under are not popped. Fuel shoots out of return line when primed. I got no popping, just cranks over and over and im desperate..
