Did you ever change your plugs and wires?
When you say "crank position sensor," are you referring to the crankshaft fluctuation sensor, the one with the reluctor wheel mounted directly to the crankshaft? The LS motor doesn't have that sensor anyway. That is only on the C motors. The LS motor does have what is defined as a crank position sensor, but it is housed with TDC and cylinder position sensors in the distributor housing. Without pretty much cutting individual wires, you have either all 3 of those sensors or none at all.
