I noticed my temp shoot up one day, quickly reaching to red on the gauge, like 220°F+, but I kept driving anyway because I thought it was a fluke, as I had just installed a new Mishimoto rad and bled the whole system. When I got back home, I lifted the engine just to check it out and noticed coolant all over my oilpan. I couldn't see it anywhere else in the engine bay. Spent a while trying to find it until I looked under. Sprayed onto the exhaust as well.
Eventually I finally noticed that way up into the bay, beneath the intake manifold, there seem to be trace amounts of the blue coolant, as well as some strange glue-like substance. Looks like it's directly connected to the back of the water pump. The weird thing is, when looking up pics, half the engines I found didn't have this weird pipe, that seems very solid like it's part of the rest of the block/head. AKA not removable. Maybe it is and they just didn't have it hooked up? I'm sure somebody knows way better than I do, hence me being here lol.
106101
106102
106103
106106
So any ideas for the solution to this somewhat severe problem? Is this whole pipe thing removable, or is it something as simple as replacing the water pump.
I have a feeling that grey glue is NOT boiled coolant lol. Very possibly done from the previous owner to fix this problem before?
The stuff it quite solid, I couldn't even peel it off with my fingers, though I couldn't get too good of a grip on it to begin with.
That pipe being black in the second pic makes me think it is indeed removable.
That’s your thermostat housing coolant pipe. It does come apart. Have to find a replacement.
Here’s a video I found.
Ah awesome, so it does come apart then. I got linked this in another forum, saying I may need to replace #16, which may be it.
I'll take it apart while still in the engine bay if I can, may be a huuuge ***** though.
See if I may need to replace the actual piping, possibly cracked apart, rather than a bad gasket.
There are 2 large o-rings on the cross pipe #18 (91314-PH7-003). Buy them in pairs because if one failed, the other isn't far behind. I would also have the #4 gasket (19305-PT0-000) on-hand too in case it's smooshed when you take apart the themo housing OR thermostat and gasket if they were not replaced when you swapped the radiator. Once the thermo housing has hoses/ sensor removed, it unbolts, hose on cross pipe removed, and finally cross pipe pulls out towards passenger side by wiggling it free. There should be NO RTV in this area (gray silicone goop that blew-out originally). Keep an old food container (e.g. Tupperware) with a few ounces of coolant in it and then dip o-rings in that before installing. Lubing them up with coolant will keep them from twisting or catching/shifting out of place while you're installing. All of this is infinitely easier if you pull the intake manifold and throttle body off first, but use your discretion to decide how deep you want to go down the rabbit hole.
106162
106163
106164
My car master suggested me use a stop leak in this case.
That's some of the worst stuff that anyone could put inside of their cooling system
