Man, one problem after another.Just fixed the sealing bolt on the solenoid, now I have a coolant leak and the motor is overheating. It's coming out where the radiator hose goes into the block. The hose is fine and tried another clamp. Still pours out from the housing..I don't see any cracks. New thermostat was installed a couple months ago.I don't see any leaks underneath. What could be going on??
The weird thing is, I turned on the AC to lubricate the seals for like 4 minutes and within 5 minutes after I turned it on, this problem started. Coincidence, ????...I've tried moving the temp lever, same result. I'm also not getting any heat, I'm assuming because coolant isn't going through the system..Is the water pump belt driven?
Thanks for help...
Month of car trouble 96_GSR
Thanks for help...
