If you read though a few articals you'll pick it up. I just did a search and had a rough time finding the answer.
In the rear...the trailing arm is the arm going parallel with the car from front to back and sits in front of the rear suspension. The Lower control arm (LCA) is the arm coming from the body under the shock and to the bottom of the hub area.
