replaced an engine mount at my buddys shop last night and upon getting rear mount and engine all back in its normal position I try to start it and it just cranks over.
If given gas 1/10 attempts it will pop over, miss, not idle and, run like complete garbage.
The car was 100% solid prior to removing the mount/reinstalling it.
I am throwing a Map code, as I am running a GM 3bar it still had no CEL prior and ran like a champ.
But now I get this Fuel supply code, this is where im stumped.
The fuel pump primes and I can smell fuel also (as i said it can get running rarely, but if pursuaded)
Main relay clicks for pump prime.
Fuel rail pressure is only ~30psi. I am running 1000cc injectors which may be the reason.
What causes the fuel supply system code?
and what would be the first place to start looking?
