I will be replacing a clutch in a friends '96 RS soon. I got an ACT HDSS setup, and was wondering what does not come with the kit, but needs to be replaced? I plan on getting the bolts that hold the pressure plate on, as well as the flywheel bolts(I will be taking it off to resurface it), and some MTF. Any other replacement parts that are recommended to pick up while at the Acura dealer? Thanks!
i'm not sure but i think you might need an alignment tool, definetly get a new throwout bearing, you don't want to use the old one
how hard is this job-- im pretty sure both axles have to some off--i usually pay like $200 plus parts which is typically around 250 for a GSR that includes clutch disc, throwout bearing and press plate----
any comments??
i just put an act clutch in my car and the kit came with everything (throw out bearing and pilot bearing) but it didnt come with the alignment tool. I had to make my own alignment tool.
