Not sure what the black plastic piece is called that is connected to my slave cylinder but it is spewing fluid when I pump my clutch. The slave is new. Any help on why it may be pouring out? Is it the pressure plate or even a new clutch? The video wouldn't upload but the black box type thing in the pic is what's attaching the slave and the tranny. At the very corner, fluid is coming out, which is slightly visible in the pic. Please help!
That black box is a rubber dust boot to protect the slave and clutch from dirt. Fluid only goes in from the feed line, and out from the bleeder on the slave. So those will be the only two options where the fluid is coming from. Could be that you didn't tighten everything down.
Discussion Starter #5
Okay, I will remove it all and see. Thanks!
