1 - 20 of 26 Posts
I was driving to work today and when I came to a light I sat there and had my car in 1st gear with the clutch pushed all the way down. All of a sudden I feel my car shake alittle and the car is slowly, very slowly moving foward but my foot is on the clutch all the way down to the ground. Then when I start to let off the clutch some more the car shakes really bad then it starts going no problem. My master clutch cylinder is leaking and a friend of mine said there prolly too much air getting into the system or has a bad seal. My clutch has not been slipping or anything. Sometimes it all goes smooth and sometimes this happens so its not the clutch, because if it was the clutch im guessing this would be happening all of the time. But since its on and off air moving around inside the system makes more sense. What do you guys think?....I might take it to a honda service center tomorrow and see what they say but I dont like how they give me answers to questions, they go like...oh its prolly that or oh its prolly this..in a being brushed off manner. Oh well, just trying to figure out what this could be...thanks =)
Please list the model teg, year, and mileage.
If you CMC is leaking then replace it and fill it up with new fluid. It should take care of your problem. If not, then it may be a clutch problem. We also have an article on diagnosing an integra clutch.
article
Bleed the system. We have an article on it. If that is no help, then it may be that your clutch is shot. Either you or a shop will have to inspect it visually. We even have an article on clutch replacement =)
It sounds as if your clutch is going. This happened to me on and for every once in a while. Really scary actually. My problem seemed to go away after I replaced my clutch, but try the troubleshooting article and do all the tests, then that way you'll be able to know for sure.
well I just came back from honda and they said its my clutch master cylinder since its a on and off problem. Reason why im trying to find out is because im on a budget and only really have enough to do one or the other kind of deal. Because I need my car..not want but need it. I cant afford to be in a situation where that I fix the clutch master cylinder and the problem is still there (meaning clutch itself). Then im screwed, but hey its my problem and no one elses untill I pay them..lol =P
well I did not get the job done yet but they said like 250-300 for clutch master and slave cylinder plus labor. I would have a friend help me do it but I dont trust myself and my friends basicly give me the impression that they dont want anything to do with it. They dont want to be held responsible if they f**k something up I guess. I rather have it done right then me learn-fix my car.
I see your point. Rather not f**k it up and have it done right. Well you should start yourself off small and work your way up. It's amazing how much money you can save on labor when you do things yourself. Purchase a Helms manual for your teg and that will be your bible. Good luck with the car.
A clutch master cylinder change isnt that hard. You can pick them up all day on ebay for like 60 new.
Discussion Starter · #13 ·
I mean I got friends with civic's and accords (late 80's early 90's) with almost 200k on them and they beat the crap out of there cars and still have the orginal clutch. So I dont see how im only at 85k and mostly drive easy on it and sometimes have alittle fun would it be the clutch. I cant wait to get this fix so I can have fun with it again =)
Yeah, a CMC change is very easy. I would help you out if your in my area. Just a piece of advice, buy the real thing from Acura. Don't go to Kragen, Monument, Car quest, etc. I am now on my fourth CMC, because I tried to go the cheap way twice. I then decided to get the real one from Acura for $120 which was discounted because I know someone. Good luck.
It sounds like your CMC definetely. I had the same problem. The Adler brand of CMC are OEM. They have Nissin stamps on the cast of the cylinder and the box has actual OEM Honda part numbers. Yes they are 60 bucks on ebay. You can buy it there or pay twice as much if u go to honda and buy it in a honda box.
Discussion Starter · #18 ·
well now its doing something new.....when im stopped and the clutch is pushed in and in 1st or whatever gear the car chatters really bad and I hear squeeking coming from the front (tranny?) and the car is trying to move foward very slowly. I try to pull it out of gear and it does come out of gear but takes alot of force. I can put it into gear but takes some force...then when I try to go it chatters really bad then goes(at the same time the engagement point is like an inch off of the floor and not half way like it was before). Ya I dont think thats the clutch master cylinder seems to be more then that :/
Discussion Starter · #20 ·
well it happened finally...this morning im up the street from my house and im at a stop sign and push the clutch in (still has feeling) and try to put it into gear...wont go into gear..I try to force it in and it grinds alittle still not going in. I got it towed to honda and they will have a look it at. I talked to the guy up there and asked how much it would cost for a new clutch just in case thats the problem...he said $440 for labor (ya clutch change is not easy) and clutch and everything that goes with it $408. Since my clutch master cylinder is leaking that might as well get replaced..they said about 200 bucks for parts and labor for that. So we are talking about 1000 bucks here. What sucks is I know im getting ripped off but I if I could do all of this myself I would. I know some people that could do it for me but they are too busy now days (work and such). When they call me back and tell me whats up ill let you all know whats going on.
1 - 20 of 26 Posts
