1 - 15 of 15 Posts
i have a 96 sp with 37k... i have intake header exhaust and i want to get the cluch and flywheel package.. will this do a lot for me, will i feel a big difference...??? or will i be wasting my time and money..?
Banned
brodydivine on Apr/12/04 said:
quarter mile and just street light to steet light...
Oh, great....
BTW, there isn't any MORE dangerous type of racing.
just be safe out there please
i put both a clutch and flywheel on my car and i love it but i auto cross and drag race so i dont know if that makes a diffrance.
Get the "mildest" clutch, then so you won't be spinning street tires. You might even be fine with a stock clutch. If you're going to run drag radials or slicks, then I'd recommend an upgrade.
As for flywheel, I haven't read up on them much so you'll have to research that yourself.
the lighter the flywheel the quicker you'll rev up and rev down simply put. I've bought the clutchmaster flywheel and it's waiting to be installed (7.8lbs I believe got it for $180 shipped new on ebay it was a dislplay in a shop and is spotless
no.. i havnt looked into the oem cluch/flywheel... but on modacar.com they have a nice cluch/flywheel package for the integra for not a bad price.. thanks for the replies.. ill be sure to be safe arwen
one more question... do u think i should have a short shifter installed while there down there???
i believe that you could get the exedy chromoly flwheel 8.8lb and exedy organic clutch for 531 from prostreetonline. that is the setup i will have by june.
and i would not reccomend act or any "pressed on" flywheels.
WHY??? ACT makes a good product...visit our sponsor...get your discount and you'll be happy...link oh and I have the 7.8lb clutchmaster one (new $180 shipped off of ebay (display model but never installed))...still waiting to be installed though
have to wait for the cash to get it installed and the cash for a new clutch
oh well....everything in time...as for the flywheel...research that...but as a basic rule the lighter it is the faster you'll be able to rev and the faster the revs will drop...with this you'll have to give it a bit more gas when you start....etc can't say that I've found someone that just hated a lightweight just read up on it and make an educated decision
Later,
Jared
90_integraLS on Apr/16/04 said:
Quote: AcuraRider14 on Apr/15/04and i would not reccomend act or any "pressed on" flywheels.
Later,
Jared
[/quote]
the reason why is that the pressed on gears on the flywheel can come off..there are stories of this happening. Exedy makes a better flywheel made from chromoly and doesnt have pressed on gears.
I have an unorthodox racing flywheel 8lbs in my 97 GSR. I noticed a pretty big difference. It revs alot smoother and faster now. Shifting is a little different then it used to. Not able to granny shift with out giving a little gas before shifting....
I have never been a fan of the multi piece FW. oNE PIECE CRO-Moly is my weapon of choice.
You will pay more for a good Fly Wheel. The design and material are dictating factors.
I hear a lot of people making claim that the Aluminum FW and other Multi piece FW have a replaceable contact surface. Well this is manily due to the fact that Aluminum is too weak and it must be suplemented with a harder metal to make for a good contact surface.
Besides I have never seen replacement contact surfaces for sale anywhere. Probably also means that you will have to replace it more often.
No but seriously I would stick with a single piece Cro-moly FW. (J's racing) Also I would not necessarily go with the lightest.
There are pros and cons to this argument. Also you want a FW the has the majority of the weight near the center b\not out towards the edges,
1 - 15 of 15 Posts
