So i just had a **** load of suspenssion work done to my car.
the symptoms: my car wasn't handling as it used to in the past and on a hard right turn, something from the front left side of the car would clunk. Also whenever i would take a turn hard, left or right, the wheel would get SO LOOSE, it felt as if the wheels would kind of lift off of the ground, ABS would kick in super easily if i'm giving brakes on a turn. this never used to happen to me. Car felt super unstable as well.
other symptoms: the car was accidently setup a little bit lower on the passenger side than on the drivers side but surprisingly for some reason my traction bar kept on ripping the boot on my axle on my drivers side (the higher side).
my setup:
tein flex coilovers, just bought last october or so,
omnipower front camber kit,
ingalls rear camber kit
skunk 2 rear lower tie bar
ride height is fender at tire in the front and in the back i have a finger gap
i have DSS stage 3 axles
jimfab tractionbar
My thoughts: I thought the clunking noise that comes on the drivers side on hard right turn was my axle, that'd had gone bad and it was causing a vibration when i'd accelerate so i figured the outer joint was gone bad as well.
so i took my car to my mechanic and he found several things wrong. and i asked him to replace a few others as good maintenance.
so here's what he replaced
he
-trimmed down the traction bar so it would clear the axle
and not touch it on turns any more
-raised up the suspenssion because he thought it was too low to handle well even though it used to be slammed when it did handle well, we set my car at the same ride height of his integra, we kept the front a little lower than the back and he set the tire pressures at 32
- changed tie rods with OEM acura tie rods
- changed front upper and lower balljoints (used Acura OEM balljoints for the lower ones and the front upper i have an omni power camber kit so i got the balljoints from omnipower)
- got a new drivers axle Driveshaftshop stage 3.9 axle that matches the DSS stage 3's that i had before (only reason the drivers one went bad was b/c the boot was ripped)
- added rear camber kit inglalls,
- rear sway bar bushings are new
- got an alignment, set toe at 0, camber at -2.5 front and -1.5 rear, set caster to stock speck (i have a traction bar so caster is adjustable)
so when we took the car for a drive, it still didnt feel stable on the highway, at 80 miles an hour my car would never EVER feel wobly in any kidn of way, but now it feels wobbly, and the tie rods are new. The car still clunks on hard right turns, the drivers side clunks still, and the car still feels as if the front wheels want to lift off the ground on a hard turn (left and right).
so what im starting to think.
why would the drivers side axle boot rip if the passengers side was lower then the drivers side?
why do the wheels feel as if they are lifting up whenever i take a hard turn?
why can my car not spin tires proporly?
im starting to think its the shocks even though the tein flex coilovers are a year old. Would they not cause these symptoms? But ive never heard of a bad shock to cause a clunking noise?
we looked through the whole car and thats the only thing he could think of that's gone bad.
my setup:
jimfab tractionbar
he
