I'm having trouble starting up my 95 Integra ls. It does one click when I turn the key.Then I let go of the clutch press it down again and repeat the process until it turns on. Any ideas on what it could be? I checked the battery my grounds and starter and they're good . Thanks in advanced
clutch saftey being faulty?, jump the wire going to the top switch and see if it starts then
As said above. Check your clutch safety switch. Its like a little button. Search for it. I did a search for you, but it was real quick and I didn't see the picture I know is on here.
