im going to paint my Brake Caliper to red, so b4 that i follow the article in the Ti to use the brake cleaner, i was just wondering if the OEM brake pad is made out of rubber?...because it saids protec all the rubber parts if u want to use the brake cleaner.
It's refering to the rubber expandable seel for the caliper bolt. If you use it sparingly it wont cause any problems.
makes sure you sand down your calipers too along with brake cleaner - anything helps to make the paint stay on better.
The only advice I have is to make sure that you dont set them on the ground when your putting them down. I did that on mine and that ended up taking off the paint and then it rusted. Ofcourse I had to blend mine upside down before I bolted them up, so that made it much more difficult for me.
