i just found a cl 3.0 for sale that has a totalled rear end, but the front is almost perfect. can i swap this engine into the teg?
From a small amount of searching on the internet, in simple terms NO!, how ever in technical terms YES!. I doubt it would be anything less than rebuilding front half of the car, you would likely have to use a large part of the oem cl front end due to size and placement issues, if you have a vast backround in engineering, fabrication, mechanics and what not I believe it would still be a huge project, .. if possible. it would more or less be a monster garage type build. so as for straight up "swaping" the motor no it wouldnt fit, youd have to swap the front end. (imo)
all this for a factory rating of 200hp and 150flb so whp would be someware around 170 and tqe 130-135? with some basic bolt ons you can put yourself in the same range for much less.
