1 - 2 of 2 Posts
hi
how can i check what code my car is throwing when the maintance light comes on. Is there a device to check the code?
Also the check engine light(maintance light) comes on one of my other cars and i was wondering if its possible to find out on that car as well. (92 Mazda MPV)
instead of going to the auto mall and getting over charged.
thanks
the maintance light and check engine light are two different lights. The maintance light is to remind morons about regularly scheduled maintance like oil changes and sh*t. The check engine light goes on when the ecu is throwing a code.
If the check engine like is on here is how you check it. There is a service connector underneath the glove compartment on the right hand side. Pull this out, it has a green cover and is a blue connector with two wires. Using a paper clip jump the connector. To read the code put key in and turn to full power(2 clicks)
The check engine light will start to flash with a series of long flashes and short flashes. The long flashes indicates the tens digit and the short flashes indicates the ones digit.
for more help go to http://www.c-speedracing.com/faq/06.html
Hope this helps
-Jon
1 - 2 of 2 Posts
