1 - 2 of 2 Posts
hey guys, i have a problem. after i put my headers,exhaust,safc,pulleys,cams on my check engine light came on 3 times, i blew the fuse for the speedo/altenator two of those times and this time i dont know why it came on but my valves or injectors are really loud now. i had a valve tap since the last time i did an oil change but now it doesnt tap, the sound is similar(not as loud) but it comes from all over the head. anyone have any clue?
Missing LMA, on the noise aspect? Or you could have just had enough piston/valve interference, that the valve is smushed out of the way.
Sounds like a host of problems. What specific DTC are you getting? Those codes will just about pin point your problems.
1 - 2 of 2 Posts
