My CEL just came on, and i used the codes to deciefer it. i got a 67, which is the catalyst system......does anyone know what this actually means? i am at school now so theres no acura dealership around me, should i bring it to a honda dealership? thanks fellas
sounds like your cat converter is on its way out. Do you hear a rattling from underneith you, or do you have any strange smells while driving?
i just installed the new cat from smsp. shouldnt be a problem......i guess in this case if i bring it to the dealership, they would make me change back to stock eh? hm....should i just take it back to the muffler shop where i got it installed?
would a header exhaust gas leakage cause this to go off? yes there is a slight smell but not too intense, you can only smell it when you are behind the car.
That new cat you installed doesnt do as good a job of cleaning the air as the stock one does, so the ecu doesnt see as big a difference in pollutants between the o2 sensor before and after the cat, giving you a CEL. The only way to alleviate the problem is with a o2 sensor emulator, something that you plug in in place of youre 2nd sensor which pretends to be an o2 sensor reading the correct amounts of pollutants.
Thanks br1t, so is it ok if i just leave it as it is? if not where can i find this o2 sensor emulator? THANKS alot
