I know the discussion about what octane should go in what model teg has been a popular one and I have done a search on this topic and read all that I can find on about it on this site.
My question here isn't about which octane I should be using, rather will I do any damage to the engine by going back to 89 octane gasoline when I've been using 93 for the past 2 years? I've heard mixed opinions about this so I'd like to kind of get an overall consensus from you all, if possible.
Thanks in advance.
there are some people who actually believe that since higher octane lowers or slows the burn rate down of the air fuel mix, going to a slightly (93->91) lower octane will help performance. Faster burn may result in more complete burn in SOME engines. For those with high compression or FI it isn't a great idea but for the average bolt-ons only car, it may actually help...or so goes the theory.
if all you have is a gs and you have not upped compression than dont go to 89. go to 87. thats all you need for a stock cr non-vtec. it can actually be worse to put in a higher octane, because higher octane fuel has more additives to it, so carbon diposits can build up with the use of a higher octane than you need. when i say it can be worse i mean very slightly be worse, and dont worry you did nothing to your car. just switch and save the money.
hootb18: You mentioned that the use of a higher octane gas in a non-vtec engine can cause carbon deposits to build up. Since I've been using 93 for a few years now I would imagine that's the case in my situation. once I make the switch back to a lower octane will those deposits remove themselves after I get into it a few times or is this something I need not worry about? Oh yeah, thanks for the re-assurance. I really appreciate it.
Mike: Are you a believer in that theory?
well as mike stated earlier and what i should have pointed out when i made my post as well is that it is a theory. but i would think that after a couple tanks of switching to 87 that the deposits would be removed because it would be a cleaner and more complete burn as mike stated earlier as well.
