Well I was watching "Burn Notice" on USA Network and he did something interesting: He wired up a cell phone to a motion detector (same idea as this)
And then I thought to myself 2 things:
1: How hard would this be (in the show he takes apart the phone etc)?
2: Would it be possible in a car?
Simple answer is, in theory it should be pretty easy. You just need:
Prepaid phone with 1 touch dialing
Alarm system of your choice
Solenoid or relay of some sort to push the correct button on your cell phone. (it can just hold the button down, although ideally it would be able to hang up and redial and recall if the alarm sounds more than once)
Sounds pretty neat huh? It could call you when your alarm goes off, or when your car starts, etc etc. Then just grab your friendly bat and run outside
Some cool things/advantages:
1: rewire the mic somewhere close to the driver and you have a bug
2: once the call is made the damage is done, even if they find and disable the phone, you already got the call
Some bad things/disadvantages:
1: Thief finds the phone and has your phone number
2: Battery life of a cheap cell phone is about 7 days... that's a lot of recharging per year (solution = inverter)
3: False alarms if you hook it up to your alarm (deep mufflers, trash pick up, etc)
Anywho, just my random idea, any comments?
