You won't be able to get rid of the CEL unless you get an o2 simulator...which most likely costs more than getting a bung welded into your cat for the sensor you have dangling.
mthurston0001 on Feb/15/06 said:
I only need the 2nd to see if the cat is working correctly, right?
correct, but usually ppl just use an 02 simulator or something similar to "trick" the ecu into thinking the cat is working fine so it doesn't throw a CEL. But iono what you can do if you don't want to get a bung put into the cat at all....except switch over to OBD1....but that seems like more work than getting a bung put in the cat.
