1999 LS Auto 144k - Bought in East Coast - so it was not a California car.
The Car is in California - Fed compliant CATs are not compliant in CA!
2021 Results compared with others:
Test MAX AVE 21-MEAS 19-Retest 2019 2017 2015 2013 2011
15mph 467 67 357 146 693 462 445 442 246
25mph 754 62 1079 646 8 34 44 78 72
1) RockAuto has several products from $100 to $500! Most do not fit CA or my LS!
I do not know which one is direct replacement - meaning no welding needed?
Pls recommend.
2) Does my car being Auto is another thing to consider when purchasing one?
Meaning stick shift vs Auto means different CAT model?
3) Last time, in 2019, it failed at 15 mph
I changed the Air Filter, Oil, and used the CatClean - it then marginally passed with slightly higher value for NO at 25mph. Wondering if CatClean damages the CAT?
If you see the table above, NO at 25mph jumped from 78 to 646 after using CatClean! Or is this expected to be random when CAT fails?
Please help me to find a direct fit that works in CA? Thanks
Pls recommend.
