1 - 2 of 2 Posts
For the car to start it needs fuel, spark, compressed air and correct timing. Something is missing, obviously. I suggest the elimination process:
1. Make sure that your battery is charged.
2. Check if there is spark
3. Check cylinder compression.
4. Make sure you have gas. Then listen if fuel pump is working. If it does, make sure injectors deliver fuel to chambers.
5. Confirm that the timing belt is installed correctly.
Post your results here.
1 - 2 of 2 Posts
