So I just finished a engine swap on 94 obd1 integra (old engine blew, still b18) at first startup, started right up and everything sounded good, no check engine lights. Until It came down from high idle to normal idle, it idled normal for about 10 seconds then dropped to 500ish and barely stayed running. It goes the same everytime, when engine is cold and on high idle mode, it idles great, revs, and moves under its own power. Then once it warms up and normal idle is triggered barely runs. Did some research and it sounds like the iacv except for the fact that once it falls to this super low idle I can floor it and nothing happens, stays at 500.
Note: same iacv, intake and most other small components from when it ran
Note 2: around the time when it blew the idle adjustment screw was lost, and Ive been trying to reset the base idle but turning the screw while doing the rest of the procedure does nothing, it just stays stuck at 500
Check mechanical timing. Make sure the cams and crank are set properly.
Sent from my iPhone using Tapatalk
