a couple of days ago i posted about my car doing nothing when i turned the key. now when i put the key the accesories turn on and everything but when i turn it to start the car it just shuts off.i think it is most likely just a bad battery but any comments or suggestions would help. thanks
I had something really similar happen. I had to replace the ignition switch. If its not the battery check you might need to have the ignition switch changed, or do it yourself its really not very hard.
i looked on the starter and didnt find a ground.is it the small wire that snaps off?the only other wire went straight to the positive terminal.
It's there...clean them all. It's not a big deal, just clean them.
Did you have someone jump it yet? If not, please do.
