undermind on Feb/23/06 said:im using a MSD blaster 3 with the Digital 6
Quote: Digital 6 Recommended Coils: PN 8207, PN 8252 or PN 8253
PN 8207 = BLASTER SS COIL SPECIFICATIoNS
Primary Resistance: .355 ohms
Peak Current: 300mA
Secondary Resistance: 6.2K ohms
Spark Duration: 180uS
Maximum Voltage: 48,000 volts
Primary Inductance:
6mH
Turns Ratio:
70:1 Tested with an MSD 6AL
measured at plug gap.
PN 8252 = BLASTER HVC COIL SPECIFICATIoNS
Primary Resistance: 0.2 ohms
Peak Current: 300mA
Secondary Resistance: 1.38K ohms
Spark Duration: 200uS
Maximum Voltage: 42,000 volts
Primary Inductance:
7mH
Turns Ratio:
100:1 Tested with an MSD 6AL
PN 8253 = BLASTER HVC II COIL SPECIFICATIoNS
Primary Resistance: 0.16 ohms
Secondary Resistance: 630 ohms
Maximum Voltage:
44,000 volts
Inductance: 3.5 mH
Turns Ratio: 100:1
Peak Current: 450 mA
Spark Duration: 450 uS
BLASTER 2 AND 3 Coil SPECIFICATIoNS
Output Voltage: 45,000 Volts Maximum
Operating Voltage: 12VDC
Primary Resistance: 0.7 Ohms
Secondary Resistance: 4.7K Ohms
Turns Ratio: 100:1
