Compressor Map
Ive tried searching on how to read these maps, but the thread was too old and the pics were hosted by imagestation (sucks). I have no idea on how to read this, its for a t3 turbo, with a 60/63 trim from a thunderbird. I want to know if this turbo would be sufficiant enough to run on the set up i want, I'm looking to make 250whp on a 97 gsr at 8-10psi on stock internals, ive been scowering all forums the past few days on all the turbo info that I can find, but i still cant figure these damn things out.
what my ideal setup would be (I know there is already plenty of these posts, but Im just throwing this out there to give more info to help me out.)
T3 turbo (Looking at 60 trim turbos)
Turbo manifold (brand unknown, still researching)
tial 35mm WG.*
2.5in down pipe
2.5/3in in/out high flow cat
custom 3in cat back exhaust
2.25 or 2.5in charge piping
FMIC
HKS BOV
aftermarket clutch
obd2-obd1 harness and ecu
Hondata s200
lots and lots of tuning
would I benefit from the use of bigger injectors, ignition, adj cam gears, anything else?
*I would really prefer to go with an external wastegate, because I've read that the internal WG would fail as the exhaust gases increase, thus causing "boostcreep" big NO-NO i know, the only turbos I can find in my price range all have internal WG,so it looks as if I'm going to have someone weld it and use an external WG, Id rather be safe than sorry.
LINK to external vs internal wastegates.
I think thats most of it, I'm still searching, man theres a lot of info and I'm still sifting through it and soaking it in. If Im missing something, please let me know.
Thanks for your time and your help.
tial 35mm WG.*
2.5in down pipe
FMIC
HKS BOV
aftermarket clutch
Hondata s200
