I took a sample from my transmission fluid and it seems like the previous owner was using engine oil for the tranny. Now I’m having some shifting issues so I want to start by changing the fluid but I wanted to switch to OE MTF. Do I have to flush the entire system or can I just do a fluid change and let the oils mix?
1998 Integra LS prepared for Road Racing
I assume this is a manual trans? If yes, no need to flush the system. Just drain it well and refill with the OE fluid. There is no cooler or other place for fluid to be trapped.
Thank you I changed out my clutch this weekend and refilled it with 2.3L like everyone says to do and it filled the tranny up perfectly.
