1 - 2 of 2 Posts
I read the article on cams, but you guys only gave the cam spec for the ITR and the GSR. Could you tell me the Intake and Exhaust lift and duration??
for B18B nonVTEC cam specs, I only have the advertised duration not the import standard at 1mm valve lift. The domestic SAE standard at 0.05 in. is useless for comparison purposes amongst import cam manufacturers. If you can get the 1mm (0.039 in.) valve lift duration spec that would be great. The @1mm valve lift duration is always less than the advertised duration.
Lift IN 10.0 mm EX 9.65 mm
Advertised Duration IN 220 degrees EX 222 degrees
The cam article here is about VTEC cams specs only for comparative purposes.
1 - 2 of 2 Posts
