HI is it posible to adjust after market cams to specific cordinates valve openings etc..on gsr motor using stock cam gears? Also how much hp type r cams usually put out with out being tuned and with being tuned? Thanks
you can adjust using stock cam gears but the adjustments will have to be one tooth at a time so the adjustments are going to be huge.
no you have to turn the cam gear one whole tooth to either way you want to turn it (left or right). Each tooth that you move the cam gear will equal a lot of cranking degrees (unknown amount) but with adjustable cam gears you can make fine adjustments and know the amount (in degrees) that you turned the camshaft.
one tooth is a pretty big turn and that could mean piston to valve contact which equals bad.
edit: when tuning you want to go by little increments not big ones
