Acuranerd on Jul/06/02 said:
Here is my reasoning. In short, the reason why overlap affects the DCR is because while you are on the compression stroke, the exhaust valve is still open, therefore you are losing some of your compression out of the exhaust. That is why FI cars use short overlap cams.
As you can all see this was a discussion I had with Acuranerd in the summer about Dynamic CR (DCR) .
Just to make sure everyone is on the same page, we were clarifying whether the exhaust side AT CAM OVERLAP affects DCR. THIS WAS A RED HERRING. I'll tell you why later on in this post. But to make sure you understand what he was trying to get at:
from the "STATIC CR - INTAKE CAM DURATIoN RELATIoNSHIP" article (please read the fine print below. the 3 underlined sections are entitled "Immediately Prior to Overlap, Valve Overlap Period Begins, Valve Overlap Period Ends" ...a little hard to read that if you don't squint). P represents the pressure in each section indicated.
at the start of cam overlap at very low valve lifts,
P3 (chamber) > P2 (exhaust manifold [EM] ) > P1 (intake port) . "Reversion" back up the intake port can occur here.
then, P1 (intake) rises to a high enough level to overcome P3 (chamber) and fills the cylinder.
if the exhaust valve is not closed at this point where P1 overcomes P3, then we get what is called "Overscavenging" and part (not all) of the intake charge goes into the header or turbo exhaust manifold, since P1 > P2 (exhaust manifold) as well.
Acuranerd was saying that DCR is also affected by the exhaust side as well since you can get the loss of cylinder pressure out the EM at overlap from overscavenging.
THE PROBLEM
The problem was in the next series of posts he goes on to relate DCR to the exhaust stroke, not the compression stroke.
PURPOSE OF THIS THREAD
The DCR Calculator that I linked to in this thread was to help you work out which cam you should get with your current static CR, since you don't want to get a cam that is too big (Overcamming the engine).
For those of you looking to make the big move to adding very aggressive aftermarket cams, the DCR Calculator tells you how much change in static CR you need to make, in order to MAINTAIN and NOT LOSE cylinder pressure below the point that you see in the stock setup.
The DCR Calculator relates to bleeding off of the cylinder pressure or cranking pressure DURING THE COMPRESSIoN STROKE. Why is this an important distinction?
The compression stroke is what builds up the baseline cranking pressure. The spark ignition of that baseline cranking pressure adds pressure on top of that to give you the huge turning force on the crank. This force that turns the crank is what generates the power (on the power stroke).
If you lose DCR (i.e. up the intake port) during this critical moment (i.e. compression and power strokes), it affects power output (i.e. less cranking pressure).
THE RED HERRING
Acuranerd diverted the attention to this critical moment and started talking about DCR and cam overlap (i.e. exhaust stroke followed by the intake stroke).
It's a red herring to divert your attention and making you look away from the key time that DCR makes a difference.
It's like focusing on the penny you just dropped on the sidewalk when a tornado is coming right at you.
Compression Ratios relate to COMPRESSIoN and the COMPRESSIoN STROKE. Whether they are static or dynamic CR. CR's relate to COMBUSTIoN or BURN. They affect the size of the burn or explosion and whether the burn is complete or not. A complete burn means there is no unburnt air-fuel mix leftover after the combustion process is finished. If you have unburnt air-fuel mix leftover, you haven't made use of any improved cylinder filling (volumetric efficiency) and you increase your emissions.
Compression Ratios don't relate to exhaust gas removal. This is what he was diverting your attention to erroneously. The hook to get your attention was the outrageous numbers he stated at the beginning (20 psi boost on a stock block and 24:1 DCR). The hook is like that penny.
This thread was about why you should use the DCR Calculator and how you should use or apply the DCR Calculator results.
Focus, focus, focus.
Don't get diverted or lose your attention from the tornado coming at you.
