Dynamic Compression Ratio Calculator (click for the hyperlink)
relationship between cam spec and CR combination calculated!!
Use this to determine your cranking pressures using stock CR with stock cams and then add aftermarket cams and vary the CR to find the best cranking pressure.
No more excuses. You shouldn't be overcamming your engine package when you upgrade your cams now.
