Today when i was trying to take off my wheel one of the lug nuts was really tight so i tried really hard to get it off and it frigging broke. Is it possible to change out the broken lug, or am i pretty much screwed.
It is possible to change out the broken lug, I myself have broken two on my teg over the past five years. The part was fifteen dollars from the dealer, and the labor was around 100+ (not sure specifically now).
Is it the front or rear lug? If it is the front then a shop will have to press out the old lug and press in a new one. If it is the rear you can do it yourself in your driveway.
you need to buy a new lug and a new bearing, you have to take the rotor assembly off and bring it to a machine shop or napa, somewheres that has a bearing press, get them to take the old bearing out, change the stud and put the new bearing in.
Damnit all its the front, so i have to have some mechanic do it?
Edit: My bad unfcknblyvbl didnt see your post yet, i think ill do what you said, thanks.
