Does anyone have info or links to a site where I can get some information on installing new brake pads on a 1997 GSR. I know how to do brake pads, but I was wondering if there are any specifics for Integras more specifically GSR's. Any help would be appreciated.
Its extremely easy.
Simply remove the lower bolt on the lower rear of the caliper. From there, you should be able to swing the caliper upwards.
(lower bolt in this pic)
Slide the previous brake pads out. Coat the new pads in anti-squeel, and install the new pads.
Using a C clamp, slowly compress the piston.
Then swing the caliper down and replace the lower bolt.
