1 - 12 of 12 Posts
Well today, I went to step on my brake pedal my brake lights turned on, an when I Let off the brake pedal the lights stayed on I lifted the brake pedal (by hand) an it turn off. what problems do you think I am Having??? is there an adjustment that can be made hopefully a quick fix...
thanks in advance
TheGSRGuy on Mar/17/04 said:
Your brake pedal pushes a button that activates the brake lamps...I'm guessing the button is stuck.
Wheres this switch at is it under the dash??
It may be Black and have a four pin connector (if car has cruise control) ....
SORRY for the Big Picture
So from this picture... I need to adjust the brake switch out am I wrong, so it can touch the brake pedal more correct??
That is also caused from lack of brake fluid in the reservoir. Filler up
Discussion Starter · #11 ·
My Break fluid is right under Max... No Leaks So I think its the Break Switch I am gonna try to adjust it out, so the pedal depresses the switch more, But My Guess is that the switch is getting worn so any one got a part number for me????
Well Its fixed now... It was the BreakSwitch The Adjustment bolt on the switch was broke.. thanks for all the Help
1 - 12 of 12 Posts
