This has been slowly getting worse with the cold weather moving in. My suspicion is the wideband sensor is bad.. When I'm cruising my afr will randomly drop to 10, the lowest reading on my meter. It also seems to be restricted/studders when casually cruising sometimes..? This doesn't happen too often.
When I am coming to a stop and take the car out of gear, as I'm cruising in neutral it will start to rev bounce and sometimes stall. It does not happen at idle at all, it is not an idle problem. I have a lot of aftermarket parts, no IACV so that can't be the culprit... Suggestions, ideas, articles you can point me to? I have done a lot of research and this is what I have come up with... Thanks T I
Also it should be noted I just got the car tuned so timing is perfect, idle was set to 900rpm.
Here is my build log for reference..
http://www.team-integra.net/forum/20-your-integra/309145-gs-r-jdm-b18c-turbo-swap.html
