1 - 2 of 2 Posts
Hard to explain on the internet but my car runs fine then bogs and shuts off but restarts right away. Changed plugs, wires, dizzy, oil, oil pressure sensor, vtec solenoid, fuel pump and a few other things. I've got a 96 integra gsr turbo on e85 only running 5.5 pounds of boost now and only has a base mat tune. Also the car is running really lean according to my AFR and I can't figure out why. I don't have the slightest idea why it's doing this and info is appreciated. Can runs great until it gets warm. Trying to fix this problem so I can get a proper tune. About to buy a new ECU and see if that fixes it.
A base map, is just that. It's to get the vehicle running before being properly tuned. A good tuner would've put safety variables in as to NOT let it create boost, reduced timing, etc. Solution - go get it tuned.
1 - 2 of 2 Posts
