1 - 19 of 19 Posts
definitely. i assume your talking about the tsunami front lip which is along w/ ww ss, are urethane. i personally have not installed these, but im pretty sure theyll fit easily. i went from body kit to body kit(all fiberglass), and now i have urethane, very easy. and the tsunami lip can be put on w/o removing the bumper, so i suggest you try it yourself first, if you need help, i know theres articles here on intalling/uninstalling side skirts, not sure about front lips though. oh yeah make sure you do it w/ a friend, its so much easier. for lip and ss, you probably only need flat head/phillips screwdriver. good luck.
sassy--
Thanks :) But I want to find the right front lip you know? There seems to be two versions of the tsunami, one with shorter fangs, and one with longer fangs. I have the post in the "Details/Appearance" forums... check it out.
Help!!
I have the Tsunami lip and it just went on with no problems.....just make sure u use the 3M tape that comes with it then drill 6 holes in it.....i have the ww sides too.....pretty easy to install but i didnt install the rear lip yet....
SlammedGSR,
Could you maybe make a tutorial out of it?
The kit is usually like a C or U shape for the front... Do i apply the 3M tape on the top of lip, place it on perfectly, then get under and screw 6 screws in across? underneath?
Let me know!
just got my ww rs kit on and man i'm happy with it , but you do have to lower your exhaust. Ithought i'd wait so i could take it to my mechcanic but it didn't hold up. (heat from emmissions melted a small piece of the kit.)get it done at the while the kit is going on.
just install it yourself.....i did my ITR front lip, Mugen style side skirts and ITR spoiler with no problems at alll.......just clean the bumper with alcohol, wipe it dry, line up the body pieces, peel back the double sided tape (if it comes with it) stick it on, and drill a couple of screws for good measure....... and holla you're done
ummm.. its pertty basic to install a bodykit or a lip. Theres only a few screws on the bumber to take it out. Theres 1 on each side of the bumber and most of the screws on are top where the hood latches down. If they say its a perfect fit. THERE Lying. NO bodykits are perfect unless you pay $1000-2000 for a Bkit and still even with that much money invested into a bodykits theres still a flaw somewhere. Depends on what type of bodykit you get too. The VIS bodykit usually fit da best from what i seen. I have the blue class bodykit, they fit like sh*t.
GreenVillian on Aug/16/02 said:
Is it possible for to install a Bomex kit. They say it is a perfect fit and I would need no modifications
they say its a perfect fit.. but the one i got i just had to do a lil minor adjustments.. i mean very minor adjustments.. but yea.. bomex is practically a perfect fit..
vi3tgsrb0i on Aug/21/02 said:
Quote: GreenVillian on Aug/16/02Is it possible for to install a Bomex kit. They say it is a perfect fit and I would need no modifications they say its a perfect fit.. but the one i got i just had to do a lil minor adjustments.. i mean very minor adjustments.. but yea.. bomex is practically a perfect fit..
yea, i guess it depends on what kind you get too. i had the knock off c-west rear put on last year from vis, it wasnt a crappy fit, but supposedly, the real c-west fits like stock.
aznleaper16 on Aug/19/02 said:
does anybody know where i can find articles on installing type-r front lips or any front lips
apparently, for the tsunami lip they come w/ tape, but for they type r lip, its really simple they just bolt rite on. didnt even take off the bumper. but i have the oem lip, cant say the same for comptech, arospeed, or any other lip.
1 - 19 of 19 Posts
