1 - 11 of 11 Posts
· Registered
I wouldn't use the ignition to try and turn the motor with the valve cover off. Remove your spark plugs and the motor turns easy with the crank. If you have a long enough extension for your socket wrench you will be able to turn the crank without needing to remove the wheel. I haven't tried the powersteering bolt method, maybe I will try that next time.
· Registered
Quote: I wouldn't use the ignition to try and turn the motor with the valve cover off. Remove your spark plugs and the motor turns easy with the crank
Cool. Same thing my bro said Surf.
· Registered
UMM You do have a manual right it should explain everything if you dont have a manual GET oNE service manuals will help you out alot if you do your own work
1 - 11 of 11 Posts
