Quote: hpracing007 on Feb/15/04If you consider a shorter geared tranny, remember that cruising on the highway will kill gas milage. If you don't care, by all means get a JDM ITR tranny.
rpm's do not dictate gas mileage. throttle position would be more correct.
Are you 100% sure about that? So you you have to near identical Integras. Same year, trim, and options. Now lets say these cars are both LS's. one has a stock LS tranny the other has a Type R/Si tranny. Gas economy will for sure be affect when cruising on the highway. . .like hpracing007 said. The difference is that at 65 the LS tranny there will be less RPM's. Where as the Type R tranny will be at a higher RPM. Now two cars going indentical speeds, the car that is in a lower gear is revving more than the other that is in a higher or in this case the one with the tighter gearing from the type R.
Sure, but let's be realistic, how many people swap gears around? Why buy two trannies? And the b16 isn't THAT great of a motor, it the tight trannies that it is usually mated with along with its higher redline that make it any faster than the b18 non-vtec motors.
Quote: BLuE_By_YoU on Feb/22/04Damn skippy that's exactly it. I just gathered some pretty good info from my brother in law he's a mechanic and told me that anything other than the stock G2 tranny is gonna be a bother to install because it will require different mounts and i think he said the mounts would have to be relocated and he also said that if you got alot of horses runnin on the B16 then the stock tranny will do. Any truth to this?
Everything except the last line is pretty much right.
Anything other than the stock G2 tranny will be hard to install? So you're saying the DIRECT FIT of a JDM B16 or USDM B17 tranny would be problematic?
And if you 'got a lot of horses' then you should keep the looser tranny in order to make sure you don't go fast? He doesn't know anything about 'a lot of horses' rather 'a lot of horsesh*t'. Stop listening to him.
I also vote for the JDM Type R Tranny if you have the funds. My friend has a JDM B16A in his 4 door civic with a JDM Type R Tranny and that tranny works wonders. Just the other day he ran a 15.2 at the track with some sh*tty tires.
It should'nt be that hard to figure out..I meant if you're running a very high powered B16 (turbo charged,head work blah blah blah) then any tranny will do including the stock G2 tranny(RS,LS etc...)
Wow, what a DUMBASS statement! Any tranny will do? Why IN THE f**kING HELL would you spend thousands to make your motor be that powerful, and then use a $200 tranny that causes you to have over 15% less torque to the ground?
Think before you type please, or do some research or SOMETHING!
Ever heard of torque multiplication? Learn it, love it, live it.
Case in point #1. B16 turbo charged engine running a close gear ratio B16 tranny. Sure the close geared transmission lays down more torque than an LS tranny. But what if your redline upshift lands you in the part of your powerband that has so much torque that you wheel spin every gear? You'd need to solve the problem of traction lost at every shift.
so say you use your b18a tranny on the b16a its going to be slower? (i am buying a b16a1 and itll be cheaper if i dont get the tranny so will it be slower or faster or not change)?
21 - 30 of 30 Posts
