Hey whats up guys, I got a JDM B16A with a GSR tranny jus wanted to know if anyone thinks there is a better tranny out there for this motor
sure there is.....but what do u mean by better??...better by gear ratios??...better by what???BLuE_By_YoU on Feb/03/04 said:Hey whats up guys, I got a JDM B16A with a GSR tranny jus wanted to know if anyone thinks there is a better tranny out there for this motor
It's probably a B17 tranny. Anyway, Louse is right. You want the tightest gearing possible up to the point where upshifting doesn't land your rpm's in the wrong part of your power band. Since you have a B16, then the tranny from the B16 would be a better match than the GSR tranny.Louse76 on Feb/03/04 said:Whatever has the tightest ratio. Tighter ratio = more torque to the ground.
Also, I see you have a '90. Is this GSR tranny a hydro? If so, it's not going to work!
Ah, the G2. great car as well as the B16 motor. Maybe I wasn't paying too close attentions, could the gearset fit? or the final drive?Louse76 on Feb/16/04 said:Much credible info on the site has shown that that is not as true as most have thought.
Also, if you were paying attention, you would know that a JDM ITR tranny won't fit on his teg.
Ah, the G2. great car as well as the B16 motor. Maybe I wasn't paying too close attentions, could the gearset fit? or the final drive?hpracing007 on Feb/16/04 said:Quote: Louse76 on Feb/16/04Much credible info on the site has shown that that is not as true as most have thought.
Everything except the last line is pretty much right. Not necessarily a G2 tranny, but anything other than a B-series cable tranny is difficult to install.BLuE_By_YoU on Feb/22/04 said:Damn skippy that's exactly it. I just gathered some pretty good info from my brother in law he's a mechanic and told me that anything other than the stock G2 tranny is gonna be a bother to install because it will require different mounts and i think he said the mounts would have to be relocated and he also said that if you got alot of horses runnin on the B16 then the stock tranny will do. Any truth to this?
rpm's do not dictate gas mileage. throttle position would be more correct.hpracing007 on Feb/15/04 said:If you consider a shorter geared tranny, remember that cruising on the highway will kill gas milage.
If you don't care, by all means get a JDM ITR tranny.
But dont they pretty much go hand in hand? Cant have high RPMs with out givin it some gas.dexmix on Feb/23/04 said:Quote: hpracing007 on Feb/15/04If you consider a shorter geared tranny, remember that cruising on the highway will kill gas milage. If you don't care, by all means get a JDM ITR tranny.
It should'nt be that hard to figure out..I meant if you're running a very high powered B16 (turbo charged,head work blah blah blah) then any tranny will do including the stock G2 tranny(RS,LS etc...)timpac167 on Feb/23/04 said:Quote: BLuE_By_YoU on Feb/22/04Damn skippy that's exactly it. I just gathered some pretty good info from my brother in law he's a mechanic and told me that anything other than the stock G2 tranny is gonna be a bother to install because it will require different mounts and i think he said the mounts would have to be relocated and he also said that if you got alot of horses runnin on the B16 then the stock tranny will do. Any truth to this?
What are you talking about in the last statement? Are you implying that if you were running a high powered B16 motor is only when you should use a stock tranny? What is alot of horses? What stock tranny? Clarify, this is the internet, not the forum of wizards and mind readers.
Try using a b16 with the A1 tranny from 90-91 or the rs/ls/gs tranny from 92-93.... i gaurantee you.. it will be unbelievably slow.BLuE_By_YoU on Feb/25/04 said:It should'nt be that hard to figure out..I meant if you're running a very high powered B16 (turbo charged,head work blah blah blah) then any tranny will do including the stock G2 tranny(RS,LS etc...)
It isn't hard for YOU to figure it out because these are thoughts in your head. You have to convey information to others properly otherwise the lines of communication become poor. Similar to ass-wipe professors who know their sh*t but can't teach a college class a day in their life.BLuE_By_YoU on Feb/25/04 said:It should'nt be that hard to figure out..I meant if you're running a very high powered B16 (turbo charged,head work blah blah blah) then any tranny will do including the stock G2 tranny(RS,LS etc...)
