There is a way to do anything. It's just have the imagination, creativity and time to complete it. If you wanted to flush out your crossovers. Placing them where the pocket is would be a great place since you probably would have enough depth. The bad part would be, you would lose your pocket and would have to refinsh the whole door panel. Refinishing a door panel is not simple at all. There are some many curves to deal with. Vinyling this is very difficult.marltonteg on Dec/27/02 said:is there a way to do it like diamonds only mount them flush in the door...and put some sort of plexiglass thing over it...mounted flush with the door...i think that would look kinda tight...maybe a neon light inside...actually maybe not...but whatever...anyone seen anything like this done/know how to do it...let me know...my sh*t is goin in tuesday and i wanna know
I used brackets, similar to what you receive with a head unit for the back support or whatever. I was lucky enough to find some heavier duty ones. I actually drilled some screws to get those crossovers mounted.zigga on May/03/03 said:What did you guys use to mount them? Double sided tape?
