I was removing the hoses off the heater core in the engine bay and bent one of them a small bit. Does anyone know what I can gently shove in there to "unbend" it?
I had the same thing happen to me. Bent the heater core tube while removing the hose. You have to be VERY careful. I had good luck using needle nose pliers and a drift chisel. But I put some bigger pliers around the outside of the pipe. So it would not deform more. Very delicate operation. As the metal tube will break off if you are not careful.
