injectors cannot cause low compression, they are mounted to the intake manifold, they do not seal the combustion chamber.
The combustion chamber is sealed by piston rings, head gasket and valves.
If you have low compression in two adjacent cyclinders it *might* be the head gasket. If you have oil in your coolant, its definitely the head gasket. You'll also get thick white billowing smoke out tailpipe.
If you rings are worn, put a teaspoon of oil in the cylinder and redo the compression check. If the compression jumps up more than 30 psi, the rings are worn.
If you've eliminated the previous two, then it is most likely the valves. Take the car to a dealer and get a leak-down test to confirm this.
