OK so I have a 2001 Acura Integra manual LS it was running great and then I got a check engine code and the car had bogged out so I plug in my OBD reader and scanned it and the code that I got is a code I’ve never seen before the code is 1607 which is ECM malfunction so I pulled the back up fuse that’s located under the hood for 10 seconds and then replaced it checked it cleared it and it came right back on so I checked the ECM plug and connector for corrosion in touch and nothing will seem to be able to place it wrong so I’m at a loss here I’ve asked numerous people if they’ve had similar issues or even seen a code like this So if you could help me please let me know thank you
