1 - 2 of 2 Posts
1998 integra rs jdm front $5000
B16c5 98 spec comeplte swap ( jdm itr) 40000km $5500
-Engine block & head
-5-Speed LSD Transmission (S80)
- P73-013
-Exhaust manifold
-Intake manifold
-Axles with Intermediate shaft
-Shifter Linkage
-Engine Mounts
-Distributor
-Injectors
-Throttle body
-Alternator
-All sensors
-Spark plugs
-Valve cover
-Oil pan
Parts
NGK spark plug wire #RC-HE82 $97
Denso double platinum spark plugs #PKJ16CR-L11#4
$127
AEM fuel rail
25-100BK
$157
Devsport tucked fuel line kit- inline filter
FLK-002-01-1-1
$216
B series RDX injector adaptor hats
INJ-BS-HAT
$33
RDX denso injectors 410cc
16450-RWC-A01
$110
AEM high flow in-tank fuel pump
50-1000
$140
AEM ajustable fuel pressure regulator
25-30XBK
$205
Ktuned fuel pressure gauge
KFR-FPG-B55
$40
B series circuit 2 x shifter
KTD-BD2-CR2
$245
Tuning
1-OBD2a-OBD1 jumper harness
1-OBD2b-OBD1 jumper harness
1-P28 ECU with Hondata S300
1-Laptop only used for tuning
Charger for laptop
Cables for S300 (data logging)
$500
Aem v2 dual chamber cold air intake
$150
Aem dry flow filter
$50
Momo apache steering wheel
$30
Viper alarm system
$330
__
98 integra type r cluster, type r middle console, front speakers, set of winter tires with steelies, magnaflow high flow full exhust
$1000
Skunk 2 alpha series 70mm throttle body, skunk 2 4 bar map sensor
$200
This is my set up, im wondering whats the realible hp number I should be looking at when I get it dyno tuned. Im from Toronto cabada please let me know some good tubers. Willing to travel tho.
All engines are different, temps will vary, etc. Not sure why you're asking....just wait until you get tuned on the dyno
But to answer your question, you have a stock R engine. You'll see anywhere from 160whp-170whp on a healthy motor.
1 - 2 of 2 Posts
