1 - 2 of 2 Posts
I've tried finding this out and im not too sure which tranny is in my integra, it's a dc4 with a b18b so im guessing it's a ls tranny but just wanted to check as it dosent have the same specs as a ls.
With the b18c swap will the tranny make a big difference to the low end power?
LS tranny has longer gears compare to GSR tranny, so acceleration would be slower with LS tranny. B18C engines are stronger than LS hence the car will be faster regardless of what tranny you have. If the sticker on the tranny is gone, I don't think you would be able to tell if its GSR or LS. However, you can take it on a freeway and record RPM/speed correlation in each gear and cross-reference your data online to see what tranny matches it.
1 - 2 of 2 Posts
