Status
Not open for further replies.
My buddy just got a complete JDM B16 Si Del Sol swap from them from for his hatch. The engine was very clean, came with all neccessary parts, believe it was right around $2200. There pretty easy to deal with, make sure everything is there, call and ask them to double check if need be.
But with his it was as said, very clean, everything was in tact and all.
Hakamoto on Feb/22/04 said:
You will also still need a manual shifter, pedals, and pretty much all the other little pieces needed to do a manual swap, minus the tranny, shift linkage, and motor mounts.
Wow, thanks you guys. Yeah when I get it I'm going to head over to the junkyard and get all the small parts I need.
Hmotorsonline rocks. They're who I got my motor through.
you'll need the clutch master cylinder, resevoir, clutchlines (hard and soft)... actually, everything about doing an auto swap has already been covered and they list everything on Hmotors that you get when you buy, so after you know that and do a search on the manual conversion you'll have all the info you need
Status
