1 - 11 of 11 Posts
Can I bolt a stock RS, LS, GS rear sway bar on a ASR subframe? I'm going to upgrade to a 22mm ITR bar, but my question is it safe and okay.
yes
It will work. someone on here has done it, and the itr sway fits on the ls without the brace, but you break the subframe like that. both bars use the same d brackets.
Did you endlink come with a spacer? The spacer should be on your LCA pushing the link out further to meet your sway bar.
Also you might have to go get some longer bolts.
Yes it did I didn't think to try the bigger spacer where the link connects to the lca. I'll try that to see if it will work.
1 - 11 of 11 Posts
