Thanks man im glad your inspired by the build this thing has come such a long way ive learned so much and had a lot of fun on the way. Your car is coming a long nice keep it upI saw that mat on ht also..I was tempted to buy it lol. Everything looks good though man. I'll be updating my build soon, I have been inspired by your teg and trying to follow in your footsteps lol.
yeah its one of those misc things that i wanted but never really thought i would need itDidnt even know they made a cf block off plate. Looks good
thanks man we have a tight crew we're like brothers it goes beyond the cars. we look each other out when it comes to parts though lolthat looks so nice, congrats on both of the pickups, you have great friends man. love seeing your updates bro keep them up
apparently most people dont lol the vinyl wrap does the job and is nice but i went the oem route thanks though!Wow I didn't know a block off plate in Faux cf existed. Looks good man! I'm going to wrap my interior pieces instead. Much cheaper![]()
lol Honda tech and nwp but mainly honda tech thoughJesus dude.
Where are you finding this stuff? Lol. That's totally rad.
I power washed my old checkered set and misted them with some dye and they look good.Nice !
I have the same set in my car now from my last integra
Unfortunately they look like a zombie threw up on them even after a good cleaning lol
Ughhhh sorry I guessssSo your the lucky dog that snagged em up before I got paid...........
It isnt a crazy bump in power but its a step in the right direction prob looking at 8-10 hp once i get my hondata tuned but eventually I wanna run skunk2 pro 1 cams with the pro series valve train and cam gears. It is a nice bump up from the gsr cams though just do dual valve springs on the exhaust side if you can. The LMA's def are working the engine is less noisy and we havent adjusted the clearances. I am pumped to drive the caragh. i want to put the itr/ctr cams and lmas in my gsr. cant wait to get a good job so i can buy parts again.
looking good as usual man.![]()
Thanks man and the new lma's are great man I def recommend theyre pricey but worth it I read a few articles that said the S2 open spring style LMA's are suppose to be %3 stiffer and they have it advertised on their site also and they cost the same as the ones i have so it might be better to get them but you can never go wrong with oemVery nice! I have been pondering putting the new style LMA's in my motor this year.
The middle rocker arm that the vtec cam lobe rests on sits on top of the lost motion over time for whatever reason the LMA's start to wear loose tension inside and eventually they wear out and cause unwanted engine noise and or chattering during idle the open spring design is Hondas replacement part to superceed the old style. Honda used these bad boys in the H series and uses em in the K's also. Skunk2 makes a set of these also they advertise theirs to be %3 stiffer then the ITR old style LMA's.What exactly does replacing the lma's do?
I have an ITR motor already which has the dual valve springs on both sides pop so I'm good but thanks for the heads up anyway lolHave u upgraded your valve springs to ITR dual valve springs? It's hard to tell in the pix... If not you better look into it! Justyn will tell you why...
Yeah man i wouldnt want to risk dropping a valve or something lol.... I by summers end I want to run S2 pro series valve springs and titanium retainers with the skunk2 pro 1 cams and i guess cam gears so they can be degree'd but that is going to cost some money but we will see eventually. If anyone has any feedback on what i just mentioned feel free to commentOk good glad you did not overlook valve springs matched to your cams needs. Now that I look at those pictures I see the blue markings on the valve springs on the exhaust side.
IIRC correctly when I had an ITR valve spring setup the intake side was yellow marked and the exhaust side (which is same as GSR intake side) were marked in blue. Hopefully I am remembering that correctly as it has been several years since I ran a setup like that.
