haven98 on Sep/26/07 said:
Is anyone here using the Skunk2 Sport Shocks because they are really cheap <$250
I am poor too so I have been putting a little money into my paypal account every time i get paid. I'm hoping that by xmas I will have enough saved to do it right. Like they said above Springs, Shocks, LCA, new LCA Bolt, Front Camber Kit and Rear if I have the money otherwise I will do the washer trick.
The H&R Springs are great! They aren't too expensive either; they're all around $150 from one of our sponsors,
Next Level Motoring. Excellent customer service.
You will need aftermarket shocks to match them though. I didn't need to buy a new LCA or LCA bolt because they weren't seized on my car, so if you're short on cash, take your wheel off and check to see if your LCA bolt is seized before you go buying things you might not need.
You don't necessarily have to use a camber kit, it's just that the camber will eat your tires up slowly. Oh, and the washer trick on the rear works like *magic*. Don't forget to get an alignment once its all done too.
Koni Yellows > Tokico Illuminas > KYB AGX
AGX's are cheapest, but won't give you as good of a ride or handling as the Koni Yellows will...
